Is the TFS stage1 cam going to be a good choice to run on a turbo application? Will be using AFR 185, Holley systemax intake, DSS 9:1 comp, on3 76mm, 55# injectors, tremec 3550 and a 3:55 gear. I have a new stage 1 already. Trick flow said its a good cam and will build cylinder pressure. I also have the AFM N61 but seems like its no good for boost (bleeds off cylinder pressure)
stock block and under 15# than yes as it won't limit you
aftermarket block than there are better choices
I'm running a TFS track heat HCI with the stage 1 cam on my basically stock but freshened bottom end.
Making 415rwhp/409rwtq @ 6K through T5, on 6psi ON3 70MM kit, Love it! Is a HOOT to drive, so drivable, my wife says drivability is way better than when N/A. Just run it! You will love it.....so far 3.5K miles on mine since June!...
I like mine!
A boost specific cam is ideal but the TFS cams will work. That's what I run and made 482 on 10 lbs. the real question is will it be worth pulling the cam to install a boost cam or not.
