1984 Mustang SVO, Doesn't look much like an SVO anymore has an 88 LX nose fit to stock SVO hood, holes from lower spats at rear wheel openings welded shut Cobra rear spoiler. Interior gutted and 10 point cage and in floor 2x3 frame connectors installed, spare tire wheel removed and RCI fuel cell installed. Mallory 110 FI fuel pump and and Aeromotive regulator, all braided hose and aeroquip fittings for fuel system custom fuel rail to fit 2.3 turbo engine. Car still has 2.3 turbo drivetrain, Koni shocks, and 4 wheel disc brakes. Rear end upgraded to an 8.8 with new 3.73 gears all new bearings and seals on a low miles rear end all rear disc components swapped over.Rear slapper bars removed and have quad shock setup avaliable. New rear upper and lower control arms with poly bushings, new brake pads, front lower K member brace, new Ebiach springs, new aluminum motorsports camber plates, OMP seat engine and mission supposed to have less than 50,000 original miles. Odometer shows around 41,000. Car needs finished (brake lines installed, engine harness finish install, battery and cables installed in rear of car, paint and some body work. $3000 or possible trades (wife wants a car).
