1 - 10 of 10 Posts
Just run the light bulb from your guage 12V+ source wire to the fuse panel under the dash. I believe it is fuse #32 or #37 check your manual. That is how i have all my guages hooked up.
Do any of you guys know where the dimmer is located I was looking all around for it and couldn't find it. I think I might just wire it to the fuse panel if the dimmer is too hard to use. Thanks for the help.
Try tapping into the dimmer control for the stereo(think it was orange). Thats what I did on my tech, works great and is allready fused.
I also did this before, It will work the way you want it to. I had no trouble for a year.
Don't recomend putting alot of gauges on it though. When I had 3 on it it did cause the other lighting on that circuit to dim. Now I just added another headlight switch on my gauge panel.
Eric
1 - 10 of 10 Posts
