1 - 16 of 16 Posts
What are you guys making with a T70? Im thinking of trading my T76 in for a T70. I want a little quicker of a spool up because its a DD.
my specs
2006 GT 298ci
8:8 Compression
Here is my T76 dynosheet
they said it may be a little restrictive on the top end HP. Thinking of a .81 or just some nitrous
do you have an .81 on your T76? I think I may try out the .81 and see what happens. How much fast will it start spooling?
also, I have 3.55 gears. This is probably a good gear for 4 gears and a turbo but I was thinking of maybe bumping it to 3.73
T-70 will get a little inefficient up top and is maxed out at 14psi.
but would work.
The T-72 stays inside the map better and has a little room to
turn up the boost.
Discussion Starter #16
how much HP you think I can squeeze out of that 72?
There is a 97 cobra with a 67 on 15lbs and hes hanging with my buddy and I who have around the same HP
1 - 16 of 16 Posts
