I'm going to buy a ON3 turbo kit. Is it worth paying the extra $400 to upgrade to a T67 or stay with the T70, street use only not a daily driver. Also do I have to change the stock K-member to install the Turbo on a 88 Foxbody. Whats the difference between the turbos.
save your money and the stock k-member is fine.
The 67 is a precision turbo. The 70 is the On3 brand (Chinese turbo)
I think the on3 70 works ok sometimes but I've heard bad stories too
Super z how is your turbo working out for you. I want to install on a stock bottom all the bolt on f-cam. What kind of HP can I see with 9lbs of boost.
I havent heard of a single On3 70mm turbo failure. I've had three of their kits, one with the MP70 upgrade. Couldn't tell a difference between the On3 Turbo and the MP.
My car is in middle of install right now.
I went with precision upgrade because 400 upgrade isn't that much the kit is still a really inexpensive kit and I figured the precision would be the safe bet for now. I'm sure I'll upgrade later but well see.
