Does anybody have any feed back good or bad about switching from a single s480 to running twin 76/68 with .81 housings, i am currently running 19# of boost but it takes a while to spool with a 96mm exhaust wheel, this is my streetcar running a 8.2 based motor with 11 to 1 compression and solid roller cam, AFR 205s and a blow through carb. car runs great right now but just looking to come out of the hole a little better. car weighs 3650 with me in it if that matters, trans is AOD-E with 4200 stall.
Been there done that, was way to small, even with the billet wheel. but thanks for the input.
I have twin 76-75 mm turbos on my 363 ci turbo 400 and it made over 1300 whp with 19.5 lbs.
How quickly do they spool/ I am running a 363 also so was thinking a 68mm exhaust wheel would work great. my 76/75 would start building boost at 2200 rpm and had full boost on the convertor even using foot brake.
They spool up very quick. I just have to change the valvebody in my tranny. My gear set is to low to get a good hit. I'm not positive on my ar I will check and let you know they are pecision billet wheels. I will let you know for sure.
I'm going from a single 76 mm to twin 66 mm on my 331 over winter. I would think as long as your exhaust housings are sized correctly, you would spool way quicker, plus have crazy power potential.
.81 for a 363 probably...I'm running .68 on my 331, but I'm shifting at 6500 with a hydraulic cam.
