Hi,
I need to replace my end links on fox body stang. I was wondering are all end links the same?
I can pick up a pair at the local advanced auto, but I was wondering if there is any performance / strength enhancements from a company like MM.
The front end suspension is stock, with the only upgrade of bushings right now.
It really doesn't matter all that much what you get, so long as the sway bar ends are level to the ground at sttic ride height. Most aftermarket end links consist of a steel tube with a bolt running through the center. That tube can be trimmed to adjust the height of the sway bar ends.
Thanks,
I noticed they all looked the same, and the prices where all the same anyways. Thanks for the info, I just picked up stockers, so we are just that much closer to rolling again.
