17x4.5 Chrome SVE Drag wheels with Mickey Thompson 28x6r17.
No scratches, scuffs, or curb rash on the wheels and never had wheel weights mounted on them. Tires run smooth and do not need wheel weights.
Had then on my 2011 mustang
Around 1,000 miles on them.
$650
Pick up only. located in Lacey, Wa.
779-242-8473
John
BENEFITS
Reduced Weight
Bolt on Center Cap
Accepts Acorn Type Lug Nuts
No Washers!
No Polishing Wheels!
No polishing wheels
FEATURES
Deep Chrome Plated Finish
Clears GT Brakes, Cobra 13" Front Brakes & GT500 Brakes
WHAT'S IN THE BOX
(1) SVE Drag Wheel
(1) Center Cap
(5) Center Cap Attaching Screws
WHEEL SPECS
Diameter 17"
Width 4.5"
Lugs 5
Offset -25 mm.
Backspacing 1.75 in.
Bolt Circle 4.5 in.
PRODUCT DESCRIPTION
SVE Drag Wheels
Get track ready looks & performance with the 17x4.5" SVE Drag Wheel for your 94-14 Mustang! This Chrome Drag Wheel is made for performance applications where weight reduction is valued. Strong and aggressive looking, the SVE Drag Wheel will give you performance with looks to match. Hub centric and secured with Acorn Type lug nuts, these wheels don't need special washers or shank lugs to fit your Mustang, saving you time at the track! Pick up a set today to launch harder and get down the drag strip or track quicker!
Why Drag Wheels?
Switching to SVE drag wheels reduces weight and allows for track specific, performance tires to be mounted on your Mustang. The front SVE wheels, known as front runners, are skinnier than regular wheels to keep your front end as light as possible. The rear wheels are offered in 8" and 10" to mount wider tires, drag radials or slicks for more traction. This allows you to launch harder and improve your ET's at the track.
Have you converted your 1979-1993 Fox Mustang to 5-lug? These SVE Wheels will fit your five lug conversion!
17” Front Wheels fit:
Fox style rotor conversion
94-04 SN95 GT Front Brakes
94-04 SN95 Cobra Front Brakes
Brake Information
- Clears GT Brakes, Cobra 13” Front Brakes, (07-12) GT500 Brakes, 11-14 Brembo upgrade brakes.
- This wheel WILL NOT clear the 13-14 GT500 15" Brembo brakes.
Note
The SVE drag wheels are not intended for street use, or for daily driving.
Wheel Specs
Offset: -25.4mm
Backspacing: 1.75"
Weight: 18lbs
Bolt Circle: 4.5
Application
- Fits: 1994-2014 Mustang GT, V6, Mach 1, Bullitt, (07-12) GT500, & Boss 302.
