ok guys what do you think i should do for my suspension setup my car is completely stock suspension looking to get in the 1.6 or 1.7's through the 60. my cat has a great deal of mods and with m/t drag radials on my stock pony wheels
Depends on how much power you have. 1.7 60 fts are easy if you have power and the right rear gears. All you need are good lower control arms and sticky tires. If you are tryting to do it with stock power then it will take a bit more work.
thanks for the reply i guess i need to give everyone a rundown on my mods. 302 with 130+ miles,bbk ceramic shorty headers with off road h pipe, gt40x heads,1.7rr's,b cam, edelbrock per. rpm upper and lower,70tb and egr,42's with matching meter, novi 1000 stock head unit pulley 8in crank, electric fan, performance automatics c4 hughes 10in 3800 stall and 3.73's. i hope this is enough for great 60's
