4.6L SOHC V8
Vortech supercharger with aftercooler
Dyno tuned making 413 rwhp / 407 tq with a safe tune on 91 octane
5-speed manual transmission
Car is blue with grey leather interior. Just turned 72k miles. Clean and clear title. Carfax report in hand. Overall good condition and is ready to be enjoyed on the street and taken to the track.
Plenty of track-enabling modifications
Driveline:
• V-2 supercharger (3.6” pulley) – Vortech
• Air-to-Water Aftercooler – Vortech
o Relocated battery to trunkl
• 42# fuel injectors – Ford Motorsports
• ’03 baffled fuel tank with dual fuel pumps – Ford Motorsports
o Replaced fuel pumps with GT Super Car Pumps
• Pro-M MAF
• Secondary oil filter feeding supercharger
• Aluminum Radiator – Fluidyne (recently replaced)
• 7-qt baffled oil pan – Canton
• Short throw shifter – Pro 5.0
• Adjustable clutch cable and quandrant – Steeda
• Torsion T2R torque-bias differential
• 3.73 ring gear and pinion – Ford Motorsports
• Exhaust
o X pipe with cats – Bassani
o Cat-back
Chasis / Suspension / Wheels / Brakes
• Full-length subframe connectors – Kenny Brown
• Strut-tower brace
• Polyurethane bushings or solid spherical bearings throughout
• 4-bolt Caster/Camber plates – Maximum Motorsports
• Front Suspension:
o DA Struts (shorter Fox specific version) – Koni
o Control arms (forward-offset = gain ½” wheelbase) – Maximum Motorsports
o Coil-over kit with 400# springs – Maximum Motorsports
o Solid steering shaft – Maximum Motorsports
o Solid steering rack bushings – Maximum Motorsports
o Bump steer kit – Baer
• Rear Suspension:
o SA Shocks – Koni
o Extreme-duty adjustable rear lower control arms – Maximum Motorsports
o Panhard bar – Maximum Motorsports
o Upper TriLink – Evolution Motorsports
o Adjustable sway bar – Maximum Motorsports
o 3” wheel studs
• Front brakes = Dual piston calipers with 13” rotors – Baer
o Hawk HPS pads (change out to “black” for track days)
o Cooling ducts (removed fog lights)
• Rear brakes = Hawk HP+ pads
• Anthracite FR500 wheels (18x9 and 18x10) – American Muscle
• Kumho Ecsta MX tires (275/35/ZR18 and 295/35/ZR18)
• 17” spare from’99 cobra (fits over 13” rotors)
Interior
• CD / Radio combo head unit – Alpine
• 4-pt roll bar with horizontal and diagonal support – Kenny Brown
• Gauges – Autometer
o Left pillar = Fuel Pressure, Boost, A/F Ratio
o Center counsel = Water Temp, Oil Pressure, Oil Temp,
• Oil pressure warning light
• RPM warning light (set to 5800 RPMs)
• Metal pedal covers
• Adjusted gas pedal position (easier to heal-toe)
Track Package
• ’95 Cobra R wheels (17x9 and 17x10.5)
• Kumho tires (255/40/ZR17 and 315/35/ZR17)
• 4-pt Rollbar with horizontal / diagonal brace
• Pro2000 competition seat – Sparco
o Manual track
o Seat back to rollbar brace
• 5-pt harnesses (blue = expired)
• 5-gallon fuel jugs (3)
• Extra front brake rotors
• Hawk front “black” pads
• Shadow Hitch and wiring for towing track trailer – Reese
I ordered the mustang new from the dealer and took possession in September ’99 (one of the first 2000s released). It was my only car while in grad school but I used alternative transportation to school (2000 thru 2005) and so was driven only sporadically and to/from track and autocrossing. Between 2008 and 2013, car was stored and has been driven on the street only since then. Has been garage stored its entire life.
Modified the chasis and suspension for cornering and track use. Autocrossed in various series through SCCA and other organizations and consistently won 1st place in modified street legal classes. Participated in and instructed at “Track Days” both at Pacific Raceway and Portland Internal Raceway with various clubs including Shelby, Mustang, Alfa and Porsche/BMW in the early 2000s.
Supercharger was installed at ~11k miles, and was recently dyno tuned by Brad’s Custom Auto to improve drivability. Currently, with the new radiator, fuel pumps and ECU tune, the car is running great and makes just over 400/400 rear wheel power.
This car is amazing to drive. Puts a smile on your face every time you step on the gas. And it actually corners on rails, which is an oxymorone for a live axle mustang, until to you hang the tail out. I love owning this car, but recently picked up a VW Golf R with 4-dr and DSG so the wife can drive it too. So it is time for the mustang to find a new home.
Any questions please ask. PM or Text. Cell: (206) 920-9268. Email: [email protected]
Asking $13,500. All reasonable offers considered, but please no low balls!
