1 - 8 of 8 Posts
I have a V3-SC going on a 347 what is the max boost I can expect to get from this unit and what pulleys will I need to reach max boost?
How do I identify it? The only identification I have found is the model # on the tag on top that says V3-SC
If you dont know exactly which head unit you have, call vortech with the serial number. I had to call to find out mine was a little SC trim.
How u figure out the mass flow on your engine?
you have two threads going?
I don't figure that out, you figure it out, its your engine
there are i assume 8 cylinders, with a 347 displacement...no?
its a 4 stroke engine, add+++ your redline rpm
and then do the math
I installed the V3 SCI last Dec on my coupe with GT 40 intake and heads, 303 cam. Havent dyno yet but i know when i installed Anderson ford power power pipe bypass system it made world of difference
1 - 8 of 8 Posts
