1 - 19 of 19 Posts
How much weight is the rear lighter than the front?
How realistic is it getting a fox to 50/50 weight distribution ?
I will install MM forward offset arms some time this summer, and set the engine 1 inch back, on top of tubular front bumper and gutted fox. Also the Torque arm/panhard bar add weight to the rear and most of the cage is in the back half of the car, im interested to see how far off from 50/50 iam. Any one use scales and dial in their track cars? What are sitting at ?
My car weighs 3,200 without me. I am 54% on the front with a 130 lb aluminum 9.5 inch block and fiberglass hood. Engine is set back with a Griggs K member and the AC is still in place. Battery is in the rear. Full interior except for the rear seat delete. A six point roll bar, TQ arm, and subframe connectors add weight to the rear mostly I would think. The T56 is heavy and does not help. Except for the AC and bumper support I am not sure how much more there is to extract from the front without getting silly.
Edit: Smog pump, charcoal canister, wiper fluid reservoir are long gone. The horn and wiper motor still exist.
Ive gutted the stock hood, Tubular front bumper, no horn, no cruise control, no ac/heat/emissions/charcoal canister. Smaller MM swaybar, tubular GT40 intake, aluminum PS/Alt brackets, coilovers, MM k member
Battery is behind passenger seat, stock motor and tranny
Anyone have scales and lives in CT or NY/NJ ?
Id really love to see how close to 50/50 i can get before i need to add weight to the rear.
Aluminum heads to would help a ton! ( i know)
It should not be that hard. My drag car is at 50/50 with a Dart Iron Eagle block, 2.8 LQ Kenne Bell S/C sitting over the engine with a custom air/water I/C as well. With me in the car the weight (per the rules I race under) is 3,150 lbs. This is with an oversize aluminum radiator, S/C coolant pump, hoses/radiator/reservoir as well. Car still has power windows.
Can you give some details on how you got to 50/50 with all that engine and blower out front? That sounds very impressive.
No A/C, No P/S, QA1 tubular K-member, coil overs, lightweight springs, no sway bar, no front bumper inner structure, Battery in right rear, 8 Gallons of water in rear I/C tank, full tank of gas, playing with the ride height front/rear. Lots of little things moved around add up.
To be fair, when a car is at 50/50 or close to it, a little bit of weight makes the number jump a lot. Here is a picture of the scale with just 5 gallons of fuel taken out of the tank.
5 gallons is 40 pounds give or take and about 1.25% of your total weight. Perhaps that is the wrong pic? Corner weighting changes can affect the cross weight but I don't think it will change the front to rear percentage.
Curious...how come the total weight went up by 1 pound? :nerd:
I will have to check my notes. Maybe I ate a big lunch...lol
1.25% of total weight that is located about as far rearward as you can get. It does effect the front/rear more than you think. It is the leverage that makes the change more than 1.25% of the front/rear bias. If it was dead center of the rear wheels, you would have a point, but it is a good 12+ inches or more behind the rear wheels.
You did not take out 8 gallons and only change the static weight by 1 pound. No amount of corner weighting changes will change the static weight although that would be nice. That was the main point I was trying to make. I will go look for corner weighting effects on front to back. I am fairly certain I have read that corner weighting will not materially change that relationship either.
Edit: I found an article by GRM on the subject. See second sentence under Setting Cross Weights.
http://grassrootsmotorsports.com/articles/understanding-corner-weights/
But to your point. Yes a change like we are discussing can have a fairly profound impact.
I suggest attending a NASA race weekend and politely asking the scales people if you can do a quick weighing. Odds are, they won't mind as long as you aren't mucking up the queue (i.e., do it when there is no queue, when a session like CMC or AI is on track). Alternatively, attend a national-level SCCA auto-x, they always have the scales there.
Discussion Starter #18
No worries man, this is why iam here to discuss.
Yes i have 1 pic of the skinned hood (granted theres more i plan on removing but yes) Its on my instagram account, scrool down a bit and you will find it.
Not to hijack the thread or anything, but, I'm looking into doing this on a junk hood I have...do you have any pics and/or a write up of what you did?
Thanks,
Mark
Discussion Starter #19
Ive read/heard that racecars are actually or preferr to be rear heavy, so when your hard on the brakes it shifts to 50/50. Love this stuff
1 - 19 of 19 Posts
