I've got some Strange 10 way struts ordered and I'm hoping it'll fix my problem. Problem is I bounce a lot on the front end which keeps unloading the rear tires so of course I keep having to get out of the throttle. I'm curious of what setting everyone has there's on? Cam show you vid if needed to explain
When n/a I ran mine on 2-3 Front and 5-8 rear depending on the track conditions. Car was making 246/310 and running 13.teens/13.oh's cutting low 1.7 60's
I haven't played with the shocks yet since moving to the turbo setup.
You run 2-3 from all the way left or right?
Start at Full Loose - 0 - which is counterclockwise until it stops. 2 clockwise clicks to tighten them up.
Thank you very much
