Here is what I did.
RUS-640850 AN -6 3/8 fuel rail fitting
RUS-610020 AN-6 strait
RUS-640940 AN-6 3/8 quick connect
'99 corvette fuel filter
RUS-640850 AN-6 3/8 fuel rail fitting
RUS-640860 AN-6 5/16 fuel rail fitting
RUS-640850 AN -6 3/8 rail fitting
RUS-641300 push on EFI fitting
I purchased 20 feet of braided fuel line AN-6 size
I removed the stock mustang fuel lines and also replaced the stock fuel pump
With a walbro 255. Look these fittings up on jegs or summit racing.
Good luck
Do you have any pics? I thought the stock mustang pump was 3/8th outlet and 1/4 inlet? I was planning on using the newer corvette filter/regulator. Aent the older filters different?
You are correct the last 2 fittings I have listed are for the stock mustang fuel pump. Put the parts number in the jegs or summit website and you'll see. I used the '99 vette filter so I can't comment on any other years. Send me a PM with your number and I'll send you pics of what I got.
How much power. 255 in tank and stock lines to the front went 9.50 in my car all I added was a adjustable regulator up front
Tim
