1 - 20 of 25 Posts
What RPM are you launching at? What is your tranny and clutch setup? Finally 60ft and quarter times.
92 LX 331 Novi 2000 18psi etc...stick of course.....
I am sure that quesions varries from setup, tune, suspension.....yada, yada, yada.
I have had problems off the line this first season of racing. Pain in the butt and getting old. The best 60' time I could muster is in the range of 2.0 to 2.2.
I actually just came back from the track a few min ago and did the same thing all night long. Best e.t. tonight was [email protected] and the last time before that was [email protected]
I am not using a 2 step or anything, just my right and left foot. I am not power shifting either.
I can hook the best if I launch betwen 1500 and 2000 rpm but softly, like leaving from a stop light but at higher rpms. Also, not mashing the gas in 1st. Probably a little bit over half way down the throttle. If I mash it down, I might as well put street tire on because it just blows all of 1st and beggining of 2nd.
My set up is 331, turbo, tko, MC Cloud twin disc (The clutch is awesome grips 1000%). I also have 3.08's in the rear. Car put down 510rwhp(street tune). I am only running 12lbs of boost. My race tune is useless at this rate, 20lbs of boost and 700+rwhp. I can't hook on 500, I don't think 200 more would help anything (never tried it though).
I am planning to go auto by the winter.
By the way, I am also running 275/40/17's MT Drag Radials.
Sorry for the long post and Good Luck!
you need some suspension. that car deff has 11s in it if your only gett 2.0 60s
Well, I run a Tremec TKOII, slipping the clutch(feathering it, bringing it straight up at a gentle pace), off the 2-step and line lock at 5000rpm. Best 60ft to date 1.51 on a 275/50/15 BFG in a Factory Stock car.
you factory stock guys are amazing. i think your class is way more a challenge having to use stock parts like that. my hats off to ya.
5500, tko600, zoom clutch....1.54 60', 11.28 @ 120 in my 88 coupe. 6000, faceplated tko600, spec stage 3 clutch, 1.45 60', 10.71 @ 122.50...93 GT(needs valve springs, should run 10.40's)
3500 rpm on the 2-step slipping the clutch and bogging (MT 235 65 15 street radials)! I need to learn how to launch with the new tires for sure. I'm running a 3550 & a custom clutch with the 2.0 60's and the times in my sig. Needless to say I'm running a tad slower than I should be. >:p
With the 3.55s - 6250 RPM and 1.62 60'
With the 4.10s - 6250 RPM and 1.59 60'
To be honest, the rev limiter is not the most consistent launch point. I have been much more consistent (1.61-1.66 on all 11 passes last time out) with the 2-step.
Best ET to date is 12.17 @ 110
N/A 347 Jerico 4-speed, Spec stage 3 clutch. Launch between 6000-7000 depending on conditions on the 2 step. 1.33-1.36 60ft's. Low 6.50's in the 1/8th.
Tremec TKO and Ram sintered iron disc clutch (too agressive).
I leave at 6,000-7,000 depending on track conditions.
1.50 60 foots and runs 11.20's @ 120 N/A
Now if you would just learn how to drive....:p
Son, it's like lightning when I shift this car. :evil:
Unless it's a big race and all the pressure is on. Then it's gonna find the high side chip trying for high gear. :eek:
1.660 at 4500 to 5000 launch dumping the spec clutch. rebuilt T-5, stock 302 longblock with carb setup and 4.10s
6500-7000, pro shifted g-force t-5, anderson hi-rev clutch, best short time of 1.54 and an [email protected] on that run. New slicks and 10's to come.
1 - 20 of 25 Posts
