1 - 14 of 14 Posts
so yesterday i pulled out my aftermarket radio to check for a preout and after putting it back together i have no doorlocks, no speedo, no clock (94-95 mustang) and i'm about ready to drive this car down a cliff. any ideas on what the heak i could have done!?! thanks
-ryan
You blew a fuse. Look at the panel under the dash.
sounds like a blown fuse or a couple of blown fuses. use butt connectors instead of electrical tape, they don't expose quite as easily.
the speedometer is also attached to a fuse?
why ask dumb questions, check it and see if it works. being that your speedo is electronic, yes it is on a fuse or fuseable link. check the link posted above and you will see that it is on a fuse.
well i changed the 50 amp fuse that controls all of the things that aren't working and the problem still persists. any other ideas?
Moderator
you might have created a short which has already blown your new fuse. Check the fuse you've just installed.
LOL, bet it's scary driving without a speedo.
check the rest of the fuses, make sure that none are blown. check the ones in the engine compartment as well. buy a cheapy multimeter to test continuity and to test voltage, make sure the lines have no breaks (continutity checker can check that, so can a idiot light that just checks to see if you have power). You could have blown a fuseable link, but check all of your fuses and relays first (easiest to replace, if you don't know how to check fuses use a continuity checker on each prong of the fuse if you hear a beep you are good).
Its a fuse. 10 amp red in the under dash fuse box. Number 15 I want to say but not 100% sure. Just take a fuse tester to each one. I'm about 99% sure because same thing happened to me.
Have you considered spending about $15 on a Haynes or Chilton's book for your car? Either will answer questions about fuses, fusable links, accessories and such.
1 - 14 of 14 Posts
