This brace installs in the chassis area between the rear wheel wells behind the rear seats which effectively couples this part of the rear structure together to increase chassis rigidity.
The reduced deflection allows the rear suspension to be more effective at doing its job.
Manufactured in house from chrome moly alloy steel tubing and mild steel brackets. Powdercoated silver with a billet aluminum center cover plate for a great appearance. Bolt on or weld in installation.
Note: Requires removal or rear seats. Custom rear seat delete or Boss 302 delete panels recommended.
Product Benefits
- 4130 Chrome Moly Design for Hardcore use also
- Better handling for more stable cornering
- Helps prevent and elimintate sqeaks and rattles
