See mods... The T/A and 4.10s were the best mods I've done. I think the T/A is the best mod for the money for a naturally aspirated car.
Jeff
civic slayer said:
what gains can i expect from steeda's timing adjuster....and is it a noticeable difference
what as far as hp do u beleiev u gained and also how do u like the 4:10's.....how high are your rpm's in 5th gear at 80mph
The T/A is worth like 5hp and 20 lbs/ft of torque, but it helps the low rpm response out alot. It helps you at all speeds, like the gears do.
The gears are great, no regrets. This is THE GEAR for a bolt on, naturally aspirated 2V. 80mph would be like 2,700rpms or so, but it is such a smooth motor you don't notice it at all. Problem is it'll cost you like $400-$600 for the gears, install, and speedcal. So if you're looking for cheap gains, the TA is still the winner in my book.
Jeff
timing adjusters are great. I have the Roush one and it works perfectly. Before I was superharged I ran between 12* usually and after the s/c I now run 14*. The torque I got from bumping it up to 14* was great!
Jeff
well im def gonna do gears but im hung between 3:73's and 4:10's...i have a 98 gt.....what do u hink is the better cause alot of people seem to have the 3:73's and say that 4:10's are too high
Remember the day you first drove your car? All I can say is after having mine for almost 2 years, I got the same readings from the butt-dyno after installing the T/A as I did when I first drove the car.
