555-4400 Steeda Competition Rear Lower Aluminum Drag Control Arms Like new. Low miles.. Comes with bushings.. $155 to your Door!!
These were $249!! These arms are designed specifically to provide ultimate traction for better 60 ft. times.
They are precision CNC-machined from light-weight, highstrength aluminum alloy and TIG welded. Each complete arm is under 3 1/2 lbs!
Competition proven at NMRA and Fun Ford events by such drivers as Jim Breese. Proven performance in 1000+ HP cars with ETs in the mid to low 8-second range.
They have poly busings. They work really well at the strip. If you put in the part number 555-4400 at Steeda.com it will tell you more.
Take Care,
Rick
