I recently was given an 04 V6 auto coupe and got a wrecked 02 GT auto vert.
I plan to swap over everything from the GT into the V6 coupe.
Plan is to pull rear end and exhaust.
Drop motor and trans on K member including hydro boost and brake lines
Drop fuel tank and lines
Install in reverse order.
Am I missing anything you guys may know?
I have done this swap on foxes before just not a 4.6 2v yet.
You might need the wiring harness from the dash too, and all the security modules from the donor so the pats will play nice.
I know I gotta swap the cluster and the PCM with the engine harness.
Nah, donor car=easy swap. Just move everything over.
