1 - 1 of 1 Posts
Hey folks,
Anyone installed one of these in a fox with aftermarket LCA's? I have a set of Global West units and the stock sway bar mounted just fine, but this suspension techniques unit does not mount flush on both sides. The driver side will mount up nicely but their is a gap on the passenger side, which does not allow the bolts to protrude properly through the LCA + swaybar.
At first I thought I needed to reuse the OEM j-hooks and not the bolts,nuts and lock washers that came with the LCAs. Upon closer inspection I noticed something strange with the passenger side mounting plate on the swaybar...it looks like it was not welded perfectly straight on the bar - Problem?
Thanks in advance,
Eric
1 - 1 of 1 Posts
