1 - 20 of 21 Posts
Whos driving on the street with a spool? Is it really a pain in the butt or not so bad? How hard is it on parts/ tires?
I would imagine that it would be really hard on the tires and most likely if you ever get caught in the rain would be very dangerous, ie one tire always breaking loose in a turn.
I just added a 33 spline built strange rear with spool to my ride. Given this is just a weekend toy/drag car that sees street time, but its not any worse than manual steering. I do like knowing that when I drive the car to/from the track its not the rear that will be breaking.
Cant say anything about its affect on tire wear, too new to me.
If you do a search this topic has been discussed a lot and you'll probably find your answers.
hth's
KS
It pushes the car pretty hard if your turning. Slowing your turning speed down will be nessicary.
Banned
Run it, you'll be fine. Just be aware of what you got, like in the rain and stuff. No biggie.
i always drive with a spool, the gt i have now is getting one very shortly. just be careful in the rain
ken
yea i was wongering about the rain i have the mickey's and manuel steering so i normally driver pretty slow in the rain and corners are taken slow also i just wanted so see how many otheres there were
Formerly known as 20thAniv
I will add that if you have 16" or 17" rims/tires that you use on the street, it will make things A LOT worse. I had a spool in my car for a short time and it really took a lot of the fun out of driving my car on the street. I have 17s with Nitto DRs and besides trying to push the front end when going around corners, if I was going around tight corners, the rear end would chatter the inside tire since there was no sidewall to soak up the twisting. I switched to the Strange/Eaton limited slip, and it's been great.
Discussion Starter #12
well i have 275/60/15's on draglites so the 17 inch wheels should not be a problem. has anyone been caught out in the rain with one and how much worse is it with a spool over the mickey t tires? I haven't heard of the Strange/Eaton limited slip so i will be looking into that also thanks
Just takes some getting used to. Like others have said, be careful when its wet. Overall, its not much difference than if you have a TIGHT differential in it.
Discussion Starter #14
the biggest spline diff i have found so far is a 31 i already have one of those i was looking for a 33 or 35 spline diff and all i have come up with are spools
Here's the one that I bought. It's advertised as a Strange differential, but when I got it, it has Eaton stamped right on it. I was in the same boat as you, with the 33 spline axles, and was able to find a few different ones, but settled on this one. It's a good unit and I'm happy with it so far.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=STR-N1867&N=700+115&autoview=sku
I got mine for a lot cheaper than Summit sells it for. I'll look around and see if I can find the guy I bought it from.
edit: Here is the info for the guy I got it from. He posts on here under "Autofab Race Cars".
[email protected]
410-796-8777
Discussion Starter #16
holy sh#$ that a bit more then i was thinking, thanks for the link. i will check out a few vendors to see it a bit cheaper
Yeah, I wasn't real happy about paying it either, but my real mistake was that I didn't buy to begin with. I ended up wasting the money on a spool and then buying the diff too. Autofab was by far the cheapest place I found. When I called up Josh, I let him know that I got the info from this site and he hooked me up with everything and I had no problems at all. It was well over $100 savings getting it from them.
You could always go with a Detroit Locker...
Discussion Starter #19
In summit the diff they have in the book was only a 31 but come to think of it they don't even have any 33 spline axles in there either... I will check one of those out also thanks
They don't make a Detoit Locker in 33 spline for an 8.8 rear end. They only make it in 33 spline for the 9". I actually asked the guys from Detroit Locker at last year's PRI show and they confirmed it.
The summit book doesn't show a lot of the stuff they actually carry. The link I put up was for the 33 spline diff though if you were talking about that one too.
1 - 20 of 21 Posts
