I'm just curious about what spark plugs some of you guys are using. I have a 347 with Victor Jr. heads. I run high 10's going threw the traps at 7100rpm. I occasionally have the problem of burning the tip of a plug. I was told it was because they were cheap passenger car plugs that should not be in a race engine (Champions). What plugs and heat ranges are you guys racing with a 347 with Victor Jr. heads using?
not a 347, but I use the autolite AR3923 plugs. They are autolite "race" plugs. never had any good luck with champions in a ford.
I run Autolite 3924's on a set of Canfields. Go through the traps at 7700. I have to richen it up a little as my plugs were a little to white for my liking.
TFS, Edelbrock, and AFR Heads:
[14mm, 3/4" Reach, 5/8" Hex, gasket seat]
AUTOLITE
1 step colder--3924 (4) [*recommended starting point]
2 step colder--3923 (3)
-----AR3933 (3) [*recessed tip, racing plug]
-----AR3932 (2) [*recessed tip, racing plug]
-----AR3931 (1) [*recessed tip, racing plug]
NGK
1 step colder--(FR5) 3686 (5) [*recommended starting point]
2 step colder--(BKR6EY) 3696 (6)
-----(R5671A-8) 4554 (8) [*recessed tip, racing plug]
-----(R5671A-9) 5238 (9) [*recessed tip, racing plug]
-----(R5671A-10) 5820 (10) [*recessed tip, racing plug]
MOTORCRAFT
1 step colder--AWSF22C
2 step colder--AWSF32C
My 347 is similar to yours...only I'm FI. I run autolight 3924's n/a...3923's on the spray. They work good for me..and are cheap. Plus just about every autoparts store carries them..heck even walmart does.
Thanks for the feedback guys. Going to try the Autolites this weekend.
