1 - 19 of 19 Posts
So I have a set of fms plug wires! On the passenger side I see that my wires at arcing every once and awhile! What's the best wires for protection from heat??
I use MSD 8.8's with the flixble straight boot and spark plug ceramic wire protectors....never had an issue
yep, my fms wires went to crap with not much use.
My FMS wires didn't last very long either. The boots stick out too far and my down pipe eventually got them. Even with DEI sleeves on them and the down pipe wrapped. I'm using Taylor Spiro Pro's now. The much shorter boots make the wires hug the block better. Still using DEI sleeves as well.
Jersey True Street Guy
I have morose ultra 40's sleeved with the heat sleeves on the boots also.
I did not have a good experience with the straight MSD's, they are a pain to get snapped on.
i had bad luck with the fms years back and have been running msd since then
although i just picked up the firecore along and dei sleeves.
I went with accel ceramic boot plugs. Love them so far. The ceramic boot also helps with routing.
Sent from my SGH-T999 using Tapatalk 2
1 - 19 of 19 Posts
