1 - 12 of 12 Posts
I am wondering if some one can explain the effects of spark blowout. I have my on3 kit on and have not the opportunity to enjoy it yet. My combo is gt40x heads, 1.7rr's, b cam. edelbrock performer rpm intake, 42's, dbx meter, anderson inline boosta pump, msd btm. The car seems to idle and cruise fine but at around 2500 it breaks up badly. I forgot to mention a forced induction intank 255 fuel pump.
no the car is not tuned and yes a msd btm. the plugs that ate in the car are 3923's gapped at 32
Formerly eades5.0
I wasnt sure which BTM you had sorry, some only allow adjustment of ignition retard and others do an ign box/ignition retard in one I do believe.
I would bring the gap down, and get a tune
-Chris
yeah i would like to get a tune but there is no shop within 8 hrs. i will close the gap down and try and tune off of the wideband and timing
Have you double checked the MAF sensor wiring to make sure it's wired up correctly if you had to splice into it?
i did have to splice into it but it was years ago when i was supercharged to extend the wiring, but i have never had any issues after. i did have a issue with the meter and have since replaced it. i am going to bring the gap down to about 25-28 and double check all of my timing. thanks for the help everyone please continue with the thoughts. i will buy myself a moates or a pms in the future to try and tune myself later down the line.
Did you ever fix your problem? Old thread - I know, but I've got a similar issue...
Jersey True Street Guy
Good ingntion hygiene needs to be followed on a forced induction cars.
-Check your grounds, MSD's and aftermarket ECU's "should" be grounded to battery
-Make sure you have clean power, right from the battery or a clean binding post.
-Check your wires, cap and rotor. Look carefully for burned and damaged wires, it happens all the time with turbo cars
-Do not use garbage coil's
Acceptable plug gap depends on the whole system working right, if you have a weak link then you may have to reduce the plug gap.
My car did not like the MSD TFI coil, but the Digital 6 hung on over 1000 rwhp. The HVCII coil worked much better for me, even in the 650 rwhp area then the TFI.
Good info there. I didnt know you could use the HVCII with the digital 6. Looks like i found my next coil.
For the record, I read somewhere that spark blowout is rare. In my case, I didn't have blowout; I had a couple small vacuum leaks and a bypass valve that didn't open. And it stuttered at 2,100 rpm exactly; every time, repeatably once it got warm.
Just fyi.
my spark blowout was cool...my car would make 3 psi and immediately cut out, like the car would die...got new plugs, closed the gap to .25 and it ran perfect after that
1 - 12 of 12 Posts
