1 - 8 of 8 Posts
I have moroso solid motor mounts
Moroso solid transmission mount
Competition engineering torque link
Competition engineering solid crossmember mounts
Bell housing on transmission is a performance automatic and is Sfi rated
Thoughts on trans or the bell housing cracking form things being to solid?
I run solid engine and trans mounts. No problems at all.
What do u use for crossmember bushings
This is my problem
I hav Solid motor and trans mounts and a torque link
I Purchased competition engineering crossmember bushings they are solid
It Said if I have solid motor and trans mounts not use the solid crossmember bushings for possibility of damage to the trans like a cracked bell or broke trans mount pad ,cracked case
I called they said that there is the possibility of damage listed above
If it is all solid and it cant move and alignment is good, how can anything break?
chassis flex
other than things in a full chassis 25.2 25.3 and some times a 25.5 i wouldnt run everything solid.
chassis flex
Interesting. I only have a 8.5 cert and run solid engine and trans mounts with no issue....then again it is on a small 26x8.5 tire so it is not seeing a huge torsional force on launch, but it is taking all of the power after 100 feet with no issues going on 3 full seasons. Maybe I am lucky, who knows.
1 - 8 of 8 Posts
