During the build of 1995 Cobra I've been keeping track of how much stuff weights as I take it off. Everything was weighted on a calibrated digital scale and I've rounded the weights to the nearest 0.1 pound. I'll add more as I go.
Front sway bar: 8.6lbs
Rear end weight/dogbone: 8.2lbs
Airbags(both): 11.5lbs (Drivers side: 2lbs, Passengers side: 9.5lbs)
Airbag crash sensors: 1.7lbs
17" cobra aluminum spare w/tire: 26.5lbs
Swapping to a manual seat track saved 8.6lbs
Square tube bracing behind rear wheels: 8.5lbs
Evap and charcoal canister: 3.7lbs
Cobra foglights and brackets: 2.22lbs (each)
Front bumper support w/Styrofoam: 17lbs
Trunk carpet and spare tire cover: 6.5lbs
Cobra oil cooler w/hoses: 4.8 lbs
EGR valve: 2lbs
EGR tube behind heads: 1.5lbs
Quadshock brackets: 7.1lbs
Rear deck carpeting and speaker grilles: 3.4lbs
Rear deck padded rear seat trim: 4lbs
Rear seat: 44lbs (Seat bottom 13.2lbs, Seat back w/frame 30.8lbs)
What is the goal?
What is the goal?
I'm just documenting what stuff weights when I am taking it out or working on it.
People say stuff is heavy or isn't heavy, but nobody ever knows the actual weights.
So your are going to be putting it all back in?
Drag car? Road Race? Street car? How much weight you looking to lose?
It’s a mostly strip car. This post is really just knowledge/data for anybody out there that might find it useful.
