1 - 15 of 15 Posts
Currently running a oil filter relocation set up with my on3 kit on a fox body. I'm considering running the smaller oil filter to help clean up under the hood some and lose the oil filter relocation kit....
Any ine running the smaller filter?
What part number/brand
Pros vs cons for going to the smaller filter?
I found a STP S16 at the local parts store that looks like its tue same size as the k&n above. I just can't find any info about it. Not sure if it has a check valve (oil drain back protection).
Wix is one of the best filters you can buy. Cut a few different filters apart and there is a difference. I run a short Wix on mine but can't remember the number off the top of my head.
I think you meant 51335 and that thing is very short. The one I run is a Wix 51085.
I tried the 51085 and it wasn't even close to fitting on my car...I went to get the 910s but they did not carry so cross referenced a Wix 51348 but it is only slightly shorter than the 51085. I may have to go with the relocation kit after all.
Sent from AutoGuide.com App
Wixs 51335 here for 2 years no problems
1 - 15 of 15 Posts
