I got a 92 coupe. Full weight. 306 with lunati cam, gt40 heads, cobra intake, underdrives, no smog, headers and exhaust. Tranny is a aod with a 2200 converter and the car has 3.73 gears. On slicks the car runs 8.6 in the eighth. With the timing backed down and a dry shot pilled to a 150 it runs a 7.90. But I also just found out that the map sensor or bap sensor whichever it is, was never plugged in or working. I got a new one on the way. Do these times seem right to ya'll? Any help would be appreciated. TIA
I think with what you have you are doing pretty good. I think a 4.10 gear would pick you up since you have a aod. thats my opinion.
my 88 vert with gtp's ,b cam, explorer intake and tb, 73 maf, 24s, 3000 stall and 373s runs consistant 8.50. has run mid to low 8.4s with good air. i would say your times are right for your combo
my convertible has been running 8.2x-8.3x @ 83mph in the 1/8th,so you're pretty much on par with the nitrous and aod i would say
