1 - 1 of 1 Posts
STREET/STRIP 1986 Mustang notchback, 89 updated nose and dash, fresh charcoal paint
Balanced 28oz. 331 cubic inch stroker, Eagle 4340 crank, Eagle h-beam rods, JE pistons reverse dome, Trick Flow aluminum heads, 202/160 valves. Lunati nitrous grind cam 276/290 duration, 536/544 lift. TFS pushrods/guideplates, Crane roller rockers, Canton oil pan/pick-up, Mellings oil pump, Ford Motorsports valve covers, Edelbrock victor junior intake, Quick Fuel Technologies 750 cfm carb, Mallory unilite Distributor, Moroso solid engine/transmission mounts, Holley fuel pump /regulator, NOS “Cheater” nitrous system 100/250 HP (never sprayed) BBK headers, 3” 40 series Flow masters , MSD blaster coil /6al ignition box, BBK under drive pulleys, AFCO radiator/ silicone hoses, Jegs Electric fan, JAZ overflow can, Moroso line lock, D&D Tubular cross member/ upper & lower control arms with Lakewood struts/ springs , Aerospace Components front hubs four piston brakes, MAC caster/camber plates, Flaming River manual rack and steering shaft, Manual brake conversion, Cobra T-5, RAM 900 series clutch, BBK quadrant/firewall adjuster, PRO-5.0 shifter, 8.8 rearend with 5 lug 33 spline Moser axles, spool and C-clip eliminators, 4:30 gears, drum brakes, MAC differential cover, Southside machine lift bars/Lakewood rear shocks, Welded 8 point cage thru the floor to the sub frame connectors, torque boxes welded. Centerline Convo-pro wheels 15 x 4.5” front 15 x 10” rear , Mickey Thompson 275/60R 15 ET street radials {brand new##, Kirkey racing seats, Autometer monster tach/shift light and liquid filled oil pressure /water temp gauges $7000.00 Chandler, Indiana Phone 812-719-2052
1 - 1 of 1 Posts
