Thinking about selling my 1986 Gt. Car is a project that I have lost interest in lately. I'm in the process of rewiring the whole chasis. I have done a carb swap on the car.
  1. 351 Windsor early block stroked to 427 (612hp/584tq @only 6K!)
  2. Forged Internals w/about 11.0 to compression
  3. Avenger Aluminum Heads w/2.08 Valves and Stage 3 Port/Polished
  4. 1.7 Roller Rockers
  5. Solid Roller Cam (252/257 @.050 dur. and .683/.685 lift w/112* lope separation
  6. Stage 3 Super Victor Intake (powder-coated)
  7. Pro-Systems Carb.
  8. New BBK Long Tubes (1 3/4s)
  9. New BBK X-Pipe (2 1/2")
  10. New Magna Flow Mufflers
  11. CSR Electric Water Pump
  12. March Electric Water Pump Bracket Kit w/Pullies
  13. Proffessional Products Distributor (with total advance locked)
  14. Fidanza Aluminum Flywheel (28 oz.)
  15. MSD Digitial 6 Ignition Box
  16. Complete Aeromotive Fuel System (sumped fuel tank,#1000 series electric fuel pump,fuel-filter,by-pass regulator) -10an fuel supply line and -08 return line
  17. Aluminum Radiator w/Black Magic Extreme Fan
  18. Engine Bay has Aluminum Fender Apron Panels
  19. Front Suspension has QA-1 K-Member w/150 lbs. Coil-Overs
  20. UPR Caster/Camber Plates
  21. Flaming River Manual Rack/Pinion
  22. Flaming River Steering Shaft
  23. Areo Space Front Vented Brakes w/Manual Brake Conversion
  24. Hurst Line Lock (new)
  25. All New Brake Hard Lines from Front to Rear
  26. Adjustable Porportioning Valve (new)
  27. Rear Suspension= Mega Bite Jrs. Lower Control Arms w/ Adjustable Uppers,Poly Urathane Bushingsl
  28. Upper/Lower Torque Boxes Reinforced
  29. 8.8 Differential w/Axles Tubes Welded
  30. 4.10 Ring/Pinion
  31. 33-Spline Axles w/ c-Clip Eliminators
  32. Rear Drag Springs w/ Air Bag
  33. Frame Connectors
  34. 8-Point Molly Cage
  35. Tremec TKO Trans w/Pro-5.0 Shifter
  36. McLoed Bell Housing
  37. DFX Clutch (new)
  38. Aluminum Drive Shaft
  39. Optima Yellow Top Battery Relocated to the Trunk
  40. Auto-Meter Gauges in Dash Cluster
  41. Plate Nos Kit
  42. 4" Fiber-glass Cowl Hood
  43. Billet-Specialites 15x4s and 15x10 Wheels
  44. New M/Ts Drag 275x60x15s Tires
  45. New M/Ts 8-Ply Front Tires
  46. New 22-Circuit Quick Wiring Kit (need to finish install)
  47. No A/C or Heat System
Pic in my album:http://s28.photobucket.com/albums/c244/racerxmd/?albumsview=slideshow
Not sure what to ask? Looking to buy a 79-86 coupe maybe. In my photobucket album have invoice of my engine build if that helps?
