A tune can be put on it to properly adjust for the changes.
Ok so I could use the stock maf with 36lbs injectors and the chip can recalibrate for the bigger injectors right?
The stock MAF is small and is not going to work with 36#'s, the meter just physically doesn't flow enough air. My advice would be a 90mm Lightning MAF for injectors that big.
Well I plan on going with an aftermarket maf one day I just wanted to know if I could get by for a little while with the stock one. And after doing a little more research I'll be going with just 30's or 32's.
