1 - 14 of 14 Posts
Bump, prices lowered!
I've got some parts for sale off my car. No problems with any of them, changing setups to a Coyote. Located in Caddo Gap, AR. Prefer not to ship heavy parts. Prices OBO.
Stock block 347 shortblock with 35k miles, forged pistons/cnc rods, cast crank, Canton oil pan, FTI cam, dressed with water pump, balancer, etc. Ran perfect, no smoking or issues other than oil pan/rear main leak - SOLD
AFR 185s "Comp" Series Heads Part #1426 58cc Chambers with ARP head studs - SOLD
Trick Flow Hardened 6.500"x0.080" Pushrods - $50
Polished EFI valve covers - SOLD
Scorpion 1.72 Rockers for 7/16 studs - SOLD
Newer Four Seasons brand AC compessor used less than a handful of times because there was a leak in the evaporator - $50
Polished Accufab 75mm Throttle Body and Spacer - SOLD
Pro-M MAF calibrated for 30# injectors - SOLD
TFS-R Upper/Lower, the upper is polished but not show quality (has plate welded in upper to keep out oil vapors) - SOLD
PA Performance 130amp 3G Alternator and Power Wire/Fuse - SOLD
Rebuilt OEM Distr with Ford Racing plug wires, MSD cap and TFI module - $70
OEM 1990 GT ECM - SOLD
Newer Motorcraft Coil - $25
2.5in X-pipe for longtubes - SOLD
BBK Fuel Pressure Reg - $25
Almost New Remy brand starter - $50
Bump, updated post with parts already sold.
Bump, someone needs these heads! Make an offer.
PM sent on heads
AFR 185s "Comp" Series Heads Part #1426 58cc Chambers with ARP head studs - $1250
Polished EFI valve covers - $30 (need polished again and has two damaged spots by the oil fill tube where my rockers hit the bottom on initial startup after HCI. Repaired with JB Weld so doesnt leak vacuum.
Pro-M MAF calibrated for 30# injectors - $90
BBK Fuel Pressure Reg - $35
Do you still have the pushrods?
1 - 14 of 14 Posts
