what header are the best fitting in a fox stang with a sbc , dynotech are 200 cheaper then kooks
I have a 88 notch with Kooks on my LS motor and they fit great but they screwed up and have them dump right at the trans cross member......i bought the AJE trans cross member 4 my th350 and had to modify it to make it work..cut and weld both sides......
I wouldnt buy the kooks if i had to do it again. The steering shaft is a very tight fit, unnecessarily too. The passenger side rubs on the aje k member as well.
if you have a aje k or team z the dyna tech stuff fits well
Tim
