Obviously timing and setup have a lot to do with it but what are some of you guys running on pump gas?
Im running a 2v with stock compression, just curious if I would be ok running 16-17 psi on pump gas.
I know guys running 20psi. Any answer you get here won't be worth a darn though when you get to the tuner. He'll tell you whats the limit for your car! But 16-17psi shouldn't be a problem. I'm running 13psi on 10.5:1 CR with TF heads on 93 Octane pump gas w/ 17' timing.
