1 - 1 of 1 Posts
Been a while and need a refresher. I’m installing an S trim on my 91. I’m about done except for a few small things.
I need some help with determining the correct belt size for the supercharger and the accessories. The car has A/C and it has smog delete which was installed on the vortech bracket.
I also need to figure out the T fitting on the oil pressure sending unit. Can anyone provide a link from Home Depot or Lowe’s on this one?
The vortech manual mentioned something about avoiding thread sealer on the feed lines. This doesn’t seem right to me. Anyone recommend using some Teflon tape?
As far as the oil return line goes. Is a good way to run this along the fuel rails until it enters the oil pan on the passenger side?
Appreciate the help guys.
1 - 1 of 1 Posts
