Sometimes when running to redline, my car backfires and shoots flames from both tailpipes.
What are the negative effects of this, if any?
Also, how do I go about correcting it? My timing is @ 12 deg and fp is @38 psi.
I'm not sure about this solution but I heard about the same thing from a friend. His car would backfire and shoot flames too. He said that he plugged the air tube that comes off of the back of the heads and connects to his H-Pipe. Apparently, this fixed his problem.
Good luck!
Vatmax
Good luck!
Vatmax
The EGR tube? What did he use to cap it off?
I'm not sure what he used but you could use a piece of high temp tubing clamped on the end of the tube and make it long enough to fold over and clamp closed. I also heard someone cut off the end of a broomstick or something and put it in there with a clamp.
All of this is hearsay. I've never personally witnessed the problem or the solution.
Good luck!
