Okay....I have a lot of work ahead of me I know...But How does this thing rotate? Don't want to mess nothing up..
Precission 76mm Turbo...
Need to rotate my exhaust housing around so that the oil drain is going now and not up? Curious do the bolts come all the way out? should I wait till I get it mounted on the headers? just was going to try and go ahead and turn it in the right direction. I can turn the Cold side of the turbo....loosen the bolts on it and it turns fine...but the Center section does not turn.
Pictures: here is the way it needs to set....So the oil Drain needs to go all the way around
Curious if these bolts do come all the way out? how do I get this one Out?
Little more effort and I got it last night....Thanks Rob
