1 - 9 of 9 Posts
All parts in Everett. E-mail me ONLY at [email protected] for info. Don't post questions in this post cause I might not get back to you!!! Brandon
ALL PARTS LISTED WERE FOR MY 1990 MUSTANG. E-MAIL ME AT [email protected] FOR DETAILS AND PRICES.
NEW - 1990 302. decks equalized, align honed, CAT steel main stud girdle, ARP rod bolts, ARP head studs, honed cylinders, moly rings, all bearings teflon coated, fly cut forged pistons (8.65:1), enlarged intake valve eyebrow, Melling HV oil pump, threaded and plugged front oil passages, Ford Motorsport 9 way timing chain, painted black. Work done by Bliss Performance in January ‘05.
NEW - Hawk (TMD) 7 qt double sump oil pan. Clearanced to fit motor above.
NEW - Professional Products chrome 50 oz SFI balancer.
NEW - AFR 185’s. Ed Curtis at Flow Tech Induction prepped. Large exhaust ports, bowls and valve seats ported / ground, high flow valves, springs and retainers good to .600”, 7/16” studs, guide plates.
NEW - Ed Curtis at Flow Tech Induction custom turbo cam. hydraulic roller, stock replacement type. 2800-6200 rpm on 302.
Trick Flow pushrods. Hardened for guide plates. Stock length. 5/16”
Ford Racing hydraulic roller lifters. 2000 miles.
Scorpion 1.6 aluminum roller rockers. 7/16” stud mount.
NEW - Cometic 4.030 multi-layer head gaskets.
Pro-thane urethane motor mounts.
NEW - HP Performance Turbo kit. Uprades include 66mm compressor, billet blow off valve, polished cold side housing, jet hot coated hot side, manual boost controller. All tubing is Jet Hot coated, 3.5” down pipe, huge intercooler, 3 Oxygen sensor bungs, 42 lb injectors, 44mm wastegate, split pipe to adapt to standard cat back.
NEW - Acufab 70mm polished TB and spacer w / EGR delete.
Ford Racing 65mm throttle body and spacer. Includes IAC and TPS
Edelbrock 70mm throttle body and spacer. 1 EGR coolant fitting needs replaced.
NEW - Professioinal Products aluminum fuel rails. Blue anodized.
NEW - (2) SX external fuel filters. -10 AN. One with paper element, one with steel.
LIKE NEW - SX external fuel pump. 500 lb / hr. -10 AN ports. Just servied by SX.
LIKE NEW - AEM Plug-n-Play stand alone EFI computer. Includes AEM Wideband UEGO O2 controller and AEM 5 bar MAP sensor. Full control of air / spark / fuel.
Ported GT-40 intake. Upper opened to accept 75mm TB, factory silver paint. Lower extensively ported by Flow Tech Induction and matched to 1250 gasket. Air temp sensor fitting tapped into side like factory.
GT-40 upper intake cover plate.
Hogan sheet metal aluminum upper intake for GT-40 lower. Needs re-polish.
Kirban adjustable aluminum fuel pressure regulator for stock rails.
C&L 76mm MAF w/ aluminum charge pipe. Includes 19 and 24 lb tubes.
C&L 80mm MAF. Includes 42lb tube.
Edelbrock Victor series water pump.
Auburn Ected electronic locking rear end diff. 28 spline. Limited slip until switch is flipped. Then is a true locked rear, like a spool. 2000 miles
Tremac World Class T5 tansmission. 4500 miles. Includes bell housing.
NEW - RAM 600 hp clutch kit. 3 finger plate, sintered iron sprung disc, throw out bearing.
Pro-5.0 shifter. Tri-Ax lever with Hurst T handle w/ button.
NEW - Steeda Tri-Ax lever
Ford Racing leather Cobra shift knob
Ford Racing aluminum driveshaft.
Ford Racing King Cobra clutch.
Lakewood SFI bellhousing.
JMS custom chip. 3 settings for N/A combo with heads, cam, intake, etc.
MSD digital 6 ignition box. Knob adjustments, no pills needed. Includes adaptor for TFI. 4500 miles.
NEW - MSD mini shift light.
MSD Blaster TFI coil.
Flex-a Lite 15” electric fan with adjustable thermostat.
Ford A/C Eliminator kit
March alternator brackets with stainless adjusting rod.
ROH ZS wheels and tires. 17x8.5” and 17 x 9.5” 5 lug wheels. 235/45-17 and 275/40-17 Sumitomo tires. Wheels great, tires so-so. Built for 94 and newer.
ROH Sniper wheels and drag tires. 17x8” and 17x9” 5 lug wheels. 205/55-17 Yokohama fronts and 275/40-17 BF Goodrich Drag Radials.
Corbeau TRS Wide black cloth seats (2) with Corbeau mounting brackets for Fox body. Slide front to back and recline. Have harness slots above shoulders.
Corbeau harness system (2). Red, cut to mount on roll bar behind seat. Not SFI.
NEW - Steeda 1/4 window molding cover kit. Restores look of weathered molding.
NEW - Perma-Cool 4 tube oil cooler. 500 hp rated. 1 1/2” x 8” x 20”
NEW - Canton aluminum rad. catch can. Direct relplacement. Clear hard anodized.
NEW - Eibach Sportline lowering spring kit. Progressive. 1.4” / 1.2”
NEW - Steeda X2 ball joints. Only fits 94 and newer spindles.
HP Motorsport 4 point K-member brace. Stiffens front end
NEW - HP Motorsport 2 point K-member brace. Stiffens front end
Tokiko Illumina 5 way adjustable struts and shocks (4). Control the ride. 7500 miles.
NEW - 5.0 intake lift plate. Works with stock, GT-40, Holley, Edelbrock, etc.
NEW - Borla 2 1/2” Turbo mufflers (2). 304 stainless, straight thru design. Mustang offset.
Magnaflow 3” chrome tips (2). decent shape, but not like new.
What would be the price to ship for the two 78526
NEW updated parts list and asking prices....
NEW - Never fired!! 1990 302. decks equalized, align honed, CAT steel main stud girdle, ARP rod bolts, ARP head studs, honed cylinders, moly rings, all bearings teflon coated, fly cut forged pistons (8.65:1), enlarged intake valve eyebrow, Melling HV oil pump, threaded and plugged front oil passages, Ford Motorsport 9 way timing chain, painted black. Work done by Bliss Performance in January ‘05. $1500
NEW - Hawk (TMD) 7 qt double sump oil pan and pick up. Clearanced to fit motor above. $200
Canton windage tray w/ studs. Fits late model 302. Very nice shape. $75
NEW - AFR 185’s. Ed Curtis at Flow Tech Induction prepped. Large exhaust ports, bowls and valve seats ported / ground, high flow valves, springs and retainers good to .600”, 7/16” studs, guide plates. $1650
NEW - Ed Curtis at Flow Tech Induction custom turbo cam. hydraulic roller, stock replacement type. 2800-6200 rpm on 302. $275
Trick Flow push rods. Hardened for guide plates. Stock length. 5/16” $75
Ford Racing hydraulic roller lifters. 2000 miles. $75
NEW - Cometic 4.030 multilayer head gaskets. SOLD
Pro-thane urethane motor mounts. $75
NEW - HP Performance Turbo kit. Uprades include 66 mm compressor, billet blow off valve, polished cold side housing, jet hot coated hot side, manual boost controller. All tubing is Jet Hot coated, 3.5” down pipe, huge intercooler, 3 Oxygen sensor bungs, 42 lb injectors, 44 mm wastegate, split pipe to adapt to standard cat back. $4500
NEW - Acufab 70 mm polished TB and spacer w / EGR delete. $205
Edelbrock 70 mm throttle body and spacer. 1 EGR coolant fitting needs replaced. $125
NEW - Professional Products aluminum fuel rails. Blue anodized. $60
NEW - SX external fuel filter. -10 AN. with paper element $45
LIKE NEW - AEM Plug-n-Play stand alone EFI computer. Includes AEM Wide band UEGO O2 controller and AEM 5 bar MAP sensor. $2100 new Full control of air / spark / fuel. $1450
GT-40 upper intake cover plate. $40
Hogan sheet metal aluminum upper intake for GT-40 lower. Needs re-polish. $300
Kirban adjustable aluminum fuel pressure regulator for stock rails. $60
C&L 76 mm MAF w/ aluminum charge pipe. Includes 19 and 24 lb tubes. $145
C&L 80 mm MAF. Includes 42lb tube. $100
Auburn Ected electronic locking rear end diff. 28 spline. Limited slip until switch is flipped. Then is a true locked rear, like a spool. 2000 miles $400
Tremac World Class T5 transmission. 4500 miles. Includes bell housing. $850
NEW - RAM 600 hp clutch kit. 3 finger plate, sintered iron sprung disc, throw out bearing. $200 - PENDING
Tri-Ax lever with Hurst T handle w/ button. $40
Ford Racing leather Cobra shift knob $25
Ford Racing aluminum drive shaft. $125
Ford Racing King Cobra clutch. $85
Lakewood SFI bell housing. $125
JMS custom chip. 3 settings for N/A combo with heads, cam, intake, etc. $100
MSD Blaster TFI coil. $30
Flex-a Lite 15” electric fan with adjustable thermostat. $145
Ford A/C Eliminator kit $25
ROH ZS wheels and tires. 17x8.5” and 17 x 9.5” 5 lug wheels. 235/45-17 and 275/40-17 Sumitomo tires. Wheels great, tires so-so. Built for 94 and newer. $750
ROH Sniper wheels and drag tires. 17x8” and 17x9” 5 lug wheels. 205/55-17 Yokohama fronts and 275/40-17 BF Goodrich Drag Radials. $750
Corbeau TRS Wide black cloth seats (2) with Corbeau mounting brackets for Fox body. Slide front to back and recline. Have harness slots above shoulders. $600
Corbeau harness system (2). Red, cut to mount on roll bar behind seat. Not SFI. $100
NEW - Steeda 1/4 window molding cover kit. Restores look of weathered molding. $75
NEW - Perma-Cool 4 tube oil cooler. 500 hp rated. 1 1/2” x 8” x 20” $100
NEW - Canton aluminum rad. catch can. Direct replacement. Clear hard anodized. $90
NEW - Eibach Sportline lowering spring kit. Progressive. 1.4” / 1.2” $175
NEW - Steeda X2 ball joints. Only fits 94 and newer spindles. $75
HP Motorsport 4 point K-member brace. Stiffens front end $35
NEW - HP Motorsport 2 point K-member brace. Stiffens front end $35
NEW - Borla 2 1/2” Turbo mufflers (2). 304 stainless, straight thru design. Mustang offset. $150
Magnaflow 3” chrome tips (2). decent shape, but not like new. $40
How much for the seats?driveshaft?and Struts and shocks? :leghump:
1 - 9 of 9 Posts
