Im going thru my engine, I have a 030 sportman block with scat rods, ross flat tops, trickflow heads, F cam and twin 60mm turbos. Ill be occasionally driving it on the street, but mostly will be drag racing it. What rings work the best on a boosted application and what ring gap should I have.
Probably a .028 top ring gap but most ring packages will tell you what you need to file them to for your app. I use Perfect Circle moly file fit.
