1 - 20 of 21 Posts
I just finished up installing the North Racecars Cobra 11.65 kit in my 86 Capri(soon to be FFR Cobra donor car).
www.northracecars.com
Bought the brackets, hardware, Fox length 5-lug axles(Yukon 28 spline), and the cables for $440, they don't list that as an option, but if you call and talk to Richard - that's the deal.
Traded in a set of junkyard core calipers at Advance Auto and a $100 for a pair of reman calipers, and another $25 for cheap pads until my Hawks get here.
Bought a set of new brake lines from Classic Tube, already modified for the brake conversion for $40(in Stainless Steel). With these tubes, this was an absolute plug and play modification.
www.classictube.com
Took about two hours to install everything except for the parking brake cables, everything fit good. As I'm changing around the parking brake lever/mechanism, I haven't assembled the new equalizer, etc. yet.
Waiting on my 8.8 girdle to get here before its maiden voyage, but all looks good, and am really pleased with both vendors.
Next up...the SN95 front spindle/Cobra caliper swap.
are they complete lines? from the center of the axle ?(at the soft line T) all the way to the sn95 rear caliper soft lines?
thx
bryan
Yes - they're the complete lines(both sides) that screw into the soft line adapter at the center of the axle housing.
I'll get some pictures tomorrow, weather permitting...and if the girdle ever shows up.
im guessing its not the same bracke north uses for the 4 lug TC disks right? or is it just the caliper and mount thats different? i may try to get this and redrill the rotors in the 4 lug pattern.
Sweet, thanx for the pics. The brackets that hold the brake lines at the end of the axle tubes, did you source that from a disc rearended mustang? It has been so long since I converted to disc I forget whether that is a drum setup part or a disc part.
1 - 20 of 21 Posts
