1 - 19 of 19 Posts
What do you guys have your rev limiters at with a stock bottom end? I have AFR 165 heads and a tfs1 cam with roller rockers but I want to make sure I get it right in the tune before I send the chip off.
Man I was thinking about making mine at 5800. I am not sure I would have any rpm to work with otherwise. I am only planning on running 6lbs because I am on stock bottom end with AFR heads.
You'll prolong your stock blocks life by keeping it under 6000 rpms
Sent from my wealth of useless knowledge!
I have mine set at 6000 RPM. Thinking of moving up to 6200 RPM.
Mine will never pop because I have Murphy's Law on my side. I have a fully assembled ready to go extra short block sitting on a stand in my garage. Mine will run until I'm dumb enough to part with my backup. :rofl:
I was at 6000 at the end of the 1320, blew a headgasket. I thought i heard detonation. so now i got set low to save the motor lol.
MYSTICSVT, how much total timing you running?
I see those kind of things dont just happen to me!!!!!!! LOL...
6200 on light 6300 on limiter Timing at 20 deg Explorer short TF 170's 13 PSI
no dyno.........but it hauls ass 100 passes so far
I set the rev limiters around 6200 to 6300 rpm, so the engine can cleanly run to 6000 rpm and shift at 6000 rpm without hitting the rev limiter.
1 - 19 of 19 Posts
