1 - 9 of 9 Posts
Why should that help a turbo setup?
Erich
my car was set up for factory stock style racing , so the stock cam was retarded 4* .
N/A with a 5 speed 4.30s and 275/60 drag radial the car went 12.24 at 111
with a 62mm 10lbs of boost , 3.08 gears , a c4 trans and a 275/50 drag radial it went 10.88 at 124.5 .
might be better set ups as far as cams go , but it works great
retarted cam
I run mine retarded 4* with 1.7 rockers , works out very nice !!!
That is a good timeslip. Is your car stripped of any weight? 124 mph is five more mph than my setup which is basically the same as yours. I am running 327's with the same tires. I am thinking to keep the gears and trying out a 28" tire.
1 - 9 of 9 Posts
