I have been wanting to do this or a long time, but I haven't found a way to retain the stock steering mounting points. Any ideas how to remove the steel from behind the dash and keep stock steering mounting points?
if your talking fox mustang, the steel in dash is seperate from steering suport and will not affect it. youl have to remove the dash to strip all the metal skelaton from it. I had to add a center support and to small tab one each end to firm dash up.(I used some 1X1 peaces of aluminium angle from home depot) .
i removed the metal skeliton from my dash on my fox i think the sn95 is the same. honestly the frame was alot lighter then i thought it was. it was only worth it cause the dash was out already.
