Probably should have asked before buying a set of headlights and tail lights off of them, but they were 20% off on eBay a week ago.
For reference, it's a set on eBay from k2motor called "Jet Black 99-04 Mustang Dual Halo Projector Headlights+Sequential LED Tail Lamps"
I keep seeing how people only say that aftermarket projector headlights have weak bulbs, so I was wondering which nice, bright, white and slightly blue LED bulbs I should install into the headlights, and yellow LED bulb for the turn signals? Should I bother with the tail lights, or will they be fine?
I did also buy these smoked fog lights off of eBay from the same seller "1999-2004 Ford Mustang V6 GT Bumper Driving Fog Lights Lamps Smoke Left+RIght"
Any recommended bulb upgrades for these? Can I use the same bulbs for headlights for these? Thanks in advance.
i know nothing of these lights
and am too lazy to look them up
try posting a link, or a spec on them
posting seller name is useless info
the only bulb you can use on the headlights that are bright will be stock halogen
if you want bright, you need to make hid xenon projectors
I don't see those as being any better than stock
and I don't see any dot labeling so they are probably illegal for street use
Most LED headlamp & fog lamp bulbs are not bright enough. If you want to use the fog lamps as DRL's, then maybe okay.
