1 - 1 of 1 Posts
Selling a rebuilt 4 Valve 10.5:1 compression Cobra engine with under 7,000 miles and in excl.running condition; teskid block bored .21 over, Kellogg 8 bolt steel crank,Manley H beam Rods,Mahle Pistons,ARP crank and rod bolts,Ford Racing main bolt kit, Mmr 8qt oil pan,04 Cobra heads,Mmr head cooling mod,Ford Racing performance head gasket kit & head studs,01 Cobra intake,BBK 65mm T.B.,24lb injectors,new PA 130 alternator,new power steering pump. All front drive accessories and engine wiring harness included to make this as complete as you can get!
$old
Call/text anytime 773-531-387two
1 - 1 of 1 Posts
