1 - 10 of 10 Posts
Alright guys i need some direction/opinions on what its gonna take to make my 8.8 handle the car in my sig. Lets call it 75% street, 25% track...
Suspension setup:
Baseline Stage 2 UCA's, LCA's, Race ARB
Tokico Illumina 5-ways
Stock GT springs
Aerospace Pro-street brakes
What about the Torque Boxes?? Just weld the seams or go ahead and call Wild Rides for an upper and lower kit?
Do i still need to worry about the quads??
As far as the rearend itself goes, this is what i have so far:
31 spline Superior C-clip axles
31 spline FRPP diff (plan on rebuilding w/ carbon clutches)
Girdle
I plan on welding the tubes, dropping the dog bone and installing a CHE axle brace.
What else can i do?? Is 31 spline and c-clips still safe for me??
If i stay 31 spline should i buy an Eaton or Detriot Tru-trac Diff and ditch the FRPP unit??
Can i get C-clip elim's for these axles, or any other 31 spline axle? Everything i see says for drum brakes...
If i go 33 spline does anybody make a streetable diff or is it pretty much all lockers and spools at that point??
Any help or insight would be much appreciated, thanks guys
Moser has a good calculator on their axle tech section to calculate max torque to the wheels. Do you know what your axles are rated?
http://www.moserengineering.com/Pages/axletech.html
That Wild Rides kit is overkill for just reinforcement. Unless you're ripped your tq boxes to shreds, just weld the seams and buy/make some plates like these: http://www.wolferacecraft.com/detail.aspx?ID=294
Quad shocks - honestly I don't know. They're there to control wheel hop, but with good UCA/LCAs you're supposed to be able to yank them. However, I don't see how they would hurt the car if you leave them on. Maybe Kevin would chime in on this?
As for the other diff/spline question... Do you have a transbrake? What tires are you running?
Another thought: If you're pulling the rear end to weld the axle tubes, what about 9" ends? Save the hassles of c-clip eliminators.
I would get rid of them. Usually there is no need for them if you have good bushings and good shocks. Once in a while when running a low profile tire wheel hop can occure but most of the time you won't need them.
hth's
ks
Keeping the quad shock will also limit the size tire you can get in there. It's in the way.
I got wheel hop with any radial tire i put on the car with or with out the quad shocks... tried adjusting pinion angle and the only thing that fixed it was a DOT slick... I have POS Mega bite Jr's and had HPM dual adj uppers... Throw em away...
thanks for the opinion's guys... looks like i wasnt too far off.
and Kevin... my suspension came in today... it was like christmas, stuff looks amazing. Great quality. Very impressed, thanks man
I would my self put in a tru-trac or an eaton and put 9" ends on or at the very least c-clip elim's. Would hate to loose a c-clip at 125+.
I have to disagree. if he's going to be launching hard, just welding the seams isn't going to cut it, better to have over kill then nothing at all.
I highly suggest the lower boxes to be reinforced but the uppers will hold just weld the seams all up.... But if you want extra security go uuper also.
I have beat the H** out of my rear suspension(several years) with Mid 1.30 60's with Kevins Uppers and All solid rear components with 5.14 gears with a T-brake with no ill effects on the upper mounting points.
1 - 10 of 10 Posts
