1 - 20 of 24 Posts
I looked into Team Z springs but they don't lower the car and I understand why. SN cars look horrible at stock ride height with a 26" tire. I currently have stiff H&R Race springs on the car. What stock replacement springs are you guys using at the track if you want a lower stance? I'm considering stock Fox V8 rear coils and they can be bought new. There are so many different stock replacement springs available at places like Rockauto. Some are progressive and others are linear. Any suggestions would be helpful.
I use these from Wolf Racecraft:
Wolfe Race Craft - Detail
To go along with these UHT springs. (UHT= Ultra High Travel)
https://www.hypercoils.com/wp-content/uploads/hyperco_catalog.pdf
With this combo, you can set rear ride height without compromising desired performance.
Thanks Saleen, but that's too permanent for me. I know it's a great setup but I'd like to be able to switch back to a stock style spring. The car is more of a street car unless I really get bitten by the racing bug.
I run Team Z drag springs. Great spring IMO. But I run MM LCA w/ adjustable spring perch.
Some people wouldn’t like this idea, but I wouldn’t mind. Buy the Team Z springs and cut them down a coil. Ya, having to cut a new spring sound horrible, but you’ll get a great drag spring, that is not bad on street, and you’ll get your desired ride height. Just a thought.
If you've got good DBL adj shocks just use 4/6 cyl springs and use the shock settings to control the suspension.
Stiff springs make it harder for the shocks to control so the shock settings/valving need to be set stiffer to control them.
ks
I have thought about this.
ks
I plan on using Strange 10 way rear shocks. I don't want too soft of a rear spring as the car sees mostly street duty for now. I know Team Z use to recommend the Fox V8 rear springs with one coil cut off.
I’d go this route if I were you, but just my opinion. My car is set up for track mostly, but I drive it on the street a fair amount. I can say I like the way the Team Z springs ride. Much better than the eibach drag springs I had. I also run Strange 10-way.
My son runs the Team Z springs and Strange 10 ways. His car does ride nice and seems to handle well. I guess I'll do the same. I'm kind of curious if the Team Z Fox springs are a different height than the SN springs. It might be worth throwing the Fox set on my '95.
Discussion Starter #12
Why don't you want "too soft of a rear spring"?
ks
Body roll in tight turns and quick freeway maneuvers. I know it's a compromise trying to balance racing with street driving. I'll settle for a happy medium. I'm hitting the track again on Jan. 5th and do not want a repeat of my last performance. Spinning through three gears was not fun nor productive. Lol. I plan on running M/T ET Street 26x10.50 15 tires instead of radials also.
ive used a few sets of team z springs and they lowered all my cars. the team z springs are rely on vehicle weight to work correctly. i believe the sn95 springs are for cars between 3300-3500lbs ...as for being worried about taking turns and the freeway just stiffen up your shocks/struts for street use
Discussion Starter #14
Read the description. Team Z states that these springs won't lower the car. Who knows....
https://lmr.com/item/LRS-9404SLRS/Mustang-Team-Z-Rear-Drag-Springs-94-04
how do you like this setup what shocks and uppers do you use
UPR adjustable uppers and Strange 10-ways. I like how it rides on the street for sure. I can’t comment on track yet, still sorting things out with my car. But I definitely recommend this setup so far
Are you using the MM drag racing version lowers
Yes I am. Impressive piece
I am presently using stock length 4cyl springs with a 28" tire. They are linear rate and have been working great for me. I have accumulated 3x sets over the years as I have changed different tire sizes and lower control arm angles on the megabite jrs I am using. The different springs help me play with ride height which changes instant center. (1coil cut, 1/2 coil cut, stock length).
1 - 20 of 24 Posts
