So i took my car to the local 1/8th mile yesterday... Combo is stock 302 bottom end, trickflow tw heads, tf stage II cam, street heat, 75mm tb/ mass air,30lb injectors and full exhaust. Still has stock 3.08 gears :rolleyes: This was my first time at the track with slicks and man I couldnt get the hang of it. Best pass was 8.18 @ 88.5 mph with a 1.91 60ft. Car weighs 3200 with me in it. It seemed that it would always bog off out of the hole and Im guessing that is because of the gears so next mod will be some 3.73's and hopefully I will see some 7.80's or so! Sound about right?
To easily solve your bogging get a msd 2 step and set it to 3500 and go from there. Play with it a bit till you get it to launch just right. After some more experiance with your set up and new gearing you should be a low 12 sec ride every time.
Thanks. Never thought it would be too hard launching with the slicks but it was def a challenge. Hopefully next time out I will see those times
