1 - 9 of 9 Posts
I used the Camaro rad for over 9 years and never had a problem
yes I used Camaro hoses, Stock Mustang hold downs, I think I had to elongate one of the brackets or both. I think the Camaro rad is a little wider but I still had room for the a/c hoses to the condenser fit with ease. I also used the Camaro dual fans. I can hotlap and make pass after pass with no heat soak. Alum block does help thou :)
Well mine will be a 6.0 with iron block, but just trying to get it on the road. I will also use the venting process for the engine.
Stock 2001 Camaro (Fbody) Radiator and the Dewit Radiator c5 Fan upgrade
Stock Fbody LS1 Hoses, stock Foxbody Hold downs
have to grind off one plastic knub on the radiator on the bottom
with my twin turbo setup, I ended up tilting it some to get the pipe for the intercooler to come up where I wanted it to...and I just made a new hold down for it at that point..
1 - 9 of 9 Posts
